I downloaded this movie, it's in AVI format, and it has a Russian voice-over over the normal english audio. The download also included an ac3 audio file that is just the regular english audio, and I don't know what to do in order to configure windows media player to play that version instead. I installed AC3filter, but I'm a complete idiot when it comes to stuff like this, so I couldn't figure out what to do from there. Does anyone know what I need to do?
Results 1 to 9 of 9
Windows Media Player is a poor choice for video with multiple audio tracks. You could try using virtualdub to remove the track you don't want, or use MPC HC or VLC for playback so you can choose the audio you want to hear.
I am not exactly clear about one point - is the english AC3 audio track in the video, or just an AC3 file in the zip download ?Read my blog here.
Try play with MPC or MPCHC, just put both files in same folder and name them like video.avi and video.ac3. Play with MPC. Then see if you change audio in mpc while playing.
Or use virtualdubmod to add the ac3 to the avi, open avi, choose video->direct stream copy, under streams add the ac3, save as a new avi. -
There is an issue with the newest version of MPC-HC and some systems. I started a thread the other day with the issue of it crashing my other machine. This machine is fine but the other machine crashed every time I tried to open MPC-HC. I installed version 1.4.2499 and everything was fine.
Also, I heard that AVIs downloaded with Russian audio on top of English audio cannot be fixed. Both languages are supposedly dubbed together on one mono track. If in fact, you do have a separate English audio file then I would use Virtualdub and choose "Audio from other file". You'll need the AC3 input plugin to add the English AC3 file. Direct Stream Copy both the video and the ac3 audio into a new AVI.
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 16:25 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 22:53 -
Playing my AVI with AC3 or WAV?
By Rudyard in forum DVD RippingReplies: 2Last Post: 11th Feb 2008, 12:41 -
Playing PCM audio within AVI file
By acid_burn in forum Newbie / General discussionsReplies: 1Last Post: 25th Dec 2007, 04:27 -
Trying to Convert avi. (Dvix) with AC3 audio file to DVD Format
By carlos305 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 09:54
