Hi,
Here is my situation. I am trying to minimize the amount of work that needs to be done in post processing. I stream video using Flash Media Encoder and end up with f4v file. I am able to play the f4v in VLC and I am happy with its quality and I would like to upload that f4v to the web. Here are my problems:
1. How can I edit the f4v file, I just want to trim the beginning and ending. No programs seems to want to accept f4v for editing. I want to edit and save it that way. I don't want to transcode it to some other format as this takes time.
2. If I do post the f4v on my website, if someone clicks on the link to watch the file, the file won't play, I do know that I need to embed a flash player on my site and the f4v will play in it. If I have a lot of videos I don't want to embed separate player for each video, Can I have 1 player and when someone clicks on a video it will just load it in that 1 player? Is that possible?
3. I can take that f4v file and simply change the extension to .mp4. I can then play that file in Quicktime with no problem and I can upload that to my site and the file plays just fine on my new Mac but when I try to play it on my older mac it won't play, the same thing for my older PC. New machines seem to play the file just fine. Why is that so? I would be happy with mp4 but I need to make sure it plays for everyone.
Can anyone help with any of this. I would be most grateful
Thank you
1. There aren't that many good flash editors. You could try avidemux, choose copy for audio and video, save as a mp4. The video wont be reconverted and it still works in flash.
2. What flash player are you using? Try google for embed flash player playlist.
3. You can try remux it to a REAL mp4, also with avidemux or mp4box. And see if it works in your old mac. -
how to open f4v(encrypted)
By atadaliran in forum Video ConversionReplies: 3Last Post: 25th Jul 2011, 13:50 -
F4V Joiner
By eaglei1982 in forum Video ConversionReplies: 0Last Post: 20th Dec 2010, 12:09 -
Can't play f4v files.
By mattstan in forum Software PlayingReplies: 5Last Post: 1st Apr 2010, 10:48 -
Youtube .f4v issue
By paxman in forum MacReplies: 1Last Post: 16th Jan 2010, 06:17 -
Blu ray from f4v
By diodorus in forum Authoring (Blu-ray)Replies: 3Last Post: 21st Oct 2009, 18:17
