Hmmm....,
I've just upgraded my C: Drive where my OS (Win 7 64-bit) and Vob2MPG Pro is installed - used Acronis to clone (64G SSD to 128G SSD) and Vob2MPg Pro has stopped working.
I get the usual message "Do you want to allow the following program from an Unknown Publisher to make change to this computer?" that I always did - but then 'zip' - the program simply doesn't launch - or if it does I don't see it - it doesn't appear in Task manager.
Any ideas? Does your security check the size of the original hard-drive perhaps? If so, I'll have a problem on my other PC where it's installed as I used my 64G SSD from my desktop as the OS and program drive in my Media Centre where another copy of VOB2MPG Pro resides - can't check as it's busy recording stuff and streaming to extenders at the moment - don't want to disturb that, but I can check tomorrow morning.
Thanks,
Phil
I just think you need to reinstall as as far as the software is concerned it is a "new" PC.
Thanks Chris,
Have done that (and now working again, thanks) - and I guess I'll have to do that on my Media-Centre too. Question: From what I remember, the licence says this can be installed on 3 PC's - if the software thinks these are new PC's does this mean I have to re-purchase, as the re-installation on the Media-Centre will be effectively number 4 (2 PC's with 2 re-installs)?
Ta,
Phil
Corel Video Studio Pro x4 has stopped working?
By TheKillerQueen in forum Capturing and VCRReplies: 6Last Post: 24th Mar 2012, 13:49 -
VOB2MPG Pro is not working for me
By BKKiran in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 8th Feb 2012, 15:58 -
Video preview not working in VOB2MPG PRO new build 3.0.0700
By Joey9 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th May 2010, 14:44 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
VOB2MPG Pro preview not working & conversion slow
By MDJH in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 22nd Sep 2009, 14:01
