    Feb 2011
    Greece
    I've posted my question up on Geneal Discussion but didnt get any response, i figured peeps here would be more able to help me
    Link to original post : https://forum.videohelp.com/threads/331762-Removing-artifacts
    Thanks for your help.
  2. You mean those little green spots that keep bouncing/flashing? Are they visible when you play the game? Only in the FRAPS cap? Only after uploading to Youtube?
    Feb 2011
    Greece
    They are visible when i play the game (actually more of them are visible in-game, less are recorded in the capture)
  4. Rather than trying to filter them out you should try to get the game to render properly in the first place.
    Feb 2011
    Greece
    It seems its a motherboard hardware problem, the noise comes up in BIOS, and with different VGAs and monitors, i dont have the $$ to get a new mobo though .
    Fixing the root cause is good advice but i'd appreciate some help with the symptoms for now, regardless of how they came up, how would you go about removing this noise?
  6. There's no easy way to eliminate all those green spots. Since they are stationary (or move back and forth between two locations) you could try using a delogo filter but you'll get blurry background colored spots instead of green spots. Or copy a nearby piece of background over them.
    Feb 2011
    Greece
    Thank you.
