Example, I have .avi (xvid) and .ts (h264), different lengths. What do you recommend to use if I want to add the audio track from .avi to .ts, without loosing quality of the video?
If you only need to add/cut at the start you could use goldwave or audacity and open the avi, edit , save as mp3 or aac. Add the audio to the ts with tsmuxer.
If you must resync in several places I would use an advanced/nle editor, import the ts video and avi audio. Start playing and fixing...this will take time...Export the video, extract the audio and add it to the ts file.
Merge multiple audio tracks from different files into 1 video file - sync
By heinza in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2012, 03:29 -
How to add audio tracks to MKV video?: mkvtoolnix problems
By LanguidLegend in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2011, 11:15 -
Align two audio tracks in sync
By dexter30 in forum Newbie / General discussionsReplies: 5Last Post: 21st Nov 2009, 09:19 -
Add an 2 video/Audio tracks to a .mov file without using Quicktime
By thomas31388 in forum Video ConversionReplies: 0Last Post: 24th Sep 2008, 15:35 -
How to add multiple audio tracks in DVDMaestro?
By rbatty11 in forum Authoring (DVD)Replies: 0Last Post: 5th Sep 2007, 07:48
