I'm looking for some recommendations on software to edit videos and create DVD's
I've got a mini DV camcorder + one of those smaller ones that records .mov movies (like the Flip)
I've used Ulead Video Studio in the past - that's been OK and fairly simple to use
I'll go with that if I can't find anything better
Are there any credible open source solutions?
Is there anything that's 'one package' - that included everything like Video Studio?
What are the best paid packages?
I'm using a PC - so looking for PC solutions
OM
Nope, there are no good open source solutions. Latest videostudio pro x3 is pretty good. Or else maybe vegas movie studio.
thanks for letting me know
i spent a little time researching on this website before asking - i'm a little surprised that there isn't an open source 'package'
i think i'm correct in saying u can get smaller bits of open source software that do everything u need
it would be great if it would be possible to have as one package
question: i've never used apple's final cut pro before - but i've heard lt's of good things about it + the ease of use and learning - how do the pc comparables compare?
i've given a go at adobe premier and after effects before - i'm sure if i'd given 20+ hours i might have got somewhere!
not user friendly for most inexperienced i would say -
If your camcorder is the type that shoots h.264 video and your computer details show what you are going to use for editing, VideoStudio would probably be your best choice. The CPU requirements for dealing with h.264 are quite high. VSP helps this by creating a proxy file of your video content, allowing lesser powered PC's to work more smoothly with it. If you are using a fast dual-core or a quad-core CPU, Vegas Movie Studio is a more robust package.
What's the best software to edit .MKV contained videos?
By creamsoda in forum EditingReplies: 12Last Post: 8th Dec 2013, 11:48 -
software to edit iphone videos on a 1.6ghz cpu, 2gb of ram, 30gb free space
By v1p0n3 in forum EditingReplies: 0Last Post: 17th Feb 2012, 06:47 -
Need software to create training videos.
By mlong30 in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Dec 2010, 10:19 -
Recommended high quality/easy DV->DVD software?
By mkanar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Apr 2010, 15:07 -
Recommended software for DVD to DivX
By craigwojo in forum DVD RippingReplies: 6Last Post: 18th Feb 2008, 08:10
