    Jan 2007
    I have an MPG file that various players say is 720x480 resolution. I was pretty sure the width wasn't one and a half times the height, so I told VLC to save a screenshot, and sure enough, the screenshot is 720x540. Why is everything saying the MPG has 720x480 resolution?
  2. Member leghorn's Avatar
    Apr 2007
    Germany
    Open the file with MediaInfo and check the resolution...
  3. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    Different players make different screenshots. Try MPC. If your file is actually 720x480 (which is most likely) you'll get a 720x480 screenshot independently of how it is displayed (I guess, it's 4:3). Don't divide 720 by 480, the AR is usually written in mpeg file header (it's either 4:3 or 16:9).
  4. Your video is probably 720x480 (NTSC DVD storage size) with a display aspect ratio (DAR) of 4:3. Media players will adjust the frame size to reflect the DAR, not the storage resolution.
    Jan 2007
    You're right, FFmpeg reports the following about the video:
    Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], 9334 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
  6. same thing here.. i used Handbrake to convert dvd(vob) file to mkv
    this is the vob file mediainfo-
    and after converting it to MKV with the help of Handbrake,,, the resolution changes
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    Handbrake resizes it to a 16:9(almost) resolution. That is normal and you can change the resolution in handbrake.
  8. hmmm will it effect the quality of the pic if suppose i change it to 720x576
    but as u said Handbrake resizes it to a 16:9(almost) resolution... its hardly any use of changeing it too 756X586
