Is there some workaround in CDRWIN for unsupported drives ?
/THX Stisse...
Which CDRW drive do you currently have ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Do what I do:
1) down load Daemon
2) mount the cue/bin file
3) use Nero and do a CD copy on the virtual drive
4) Don't have to worry about CDRwin not support the drive
tinman -
I have a drive that is not supported by CDRWin, too. I used to use Fireburner instead (which works great). Now I use Nero version 5.5.7.2, and it works perfectly. Although Nero didn't use to burn bin/cue files correctly, the latest versions do. tinmancp's method of mounting to Daemon first and then doing a CD copy is a smart idea, but it's no longer necessary.
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 14:17 -
please help: unsupported mHz in Adobe 6.0
By chicagomama in forum EditingReplies: 5Last Post: 18th Oct 2010, 22:32 -
PSP saying unsupported Data.
By kumar66 in forum Newbie / General discussionsReplies: 7Last Post: 14th Nov 2009, 22:32 -
Unsupported codec (id = 0) in ffmpeg
By Nightslk in forum Video ConversionReplies: 3Last Post: 10th Nov 2009, 17:17 -
TMPGEnc Plus 2.5 saying unsupported??
By Suprman37 in forum Video ConversionReplies: 10Last Post: 12th Oct 2007, 17:51
