If you have a large amount of VHS to digitize, and/or do alot of SD analog TV capturing you really should consider dedicating an XP box for the task.
This is regardless of whether or not you buy the 600, or other similar product, or even a Canopus, etc. It just makes sense - undisturbed capturing, no burdening/stressing your regular PCs and their hard drives, no messing with O/S settings or making special accomadations, and no need for over-rated hardware based encoders.
If you shop around, you can get a tower used, that is 4-5 years old, 2-core, for under $100, and would be fit for the job - and save a ton of headaches.
Results 91 to 102 of 102
I hate VHS. I always did.
I have a dual core W7 laptop. I'm going to buy a new 500 GB HD for it and load XP onto it. Hopefully, that's going to work!
I did voporeon800's trick and got the driver recognized but couldn't get any software to work with the now recognized driver with W7. The new HD is only $50 so, hopefully it will do the trick. I'll keep the HD for any video projects and keep XP loaded on it for any old programs which might require it.
Thanks to everyone who has helped on this thread. -
Ah phooey. Get a 2TB instead for maybe only 20%-30% more price.Originally Posted by dorenhagen
I prefer capturing to a separate PC entirely, but a different drive, or even partition, and an XP boot can work too and would be worth it to use the 600 IMO. All my other capture tools are collecting dust now - seriously.
Let us know how it works out for you.I hate VHS. I always did. -
[QUOTE=PuzZLeR;2059952]
I will post as soon as I load XP, the drivers and software.Originally Posted by dorenhagen
Puzzler, have you directly compared DV/AVI capture converted to MPEG-2 to direct capture with the AVI USB device?
What program do you use to capture the video images that you post here?
Thanks. -
I did from other capture devices in the past, but thanks for reminding me - I'm curious now to see what I'd find with the 600.Originally Posted by dorenhagen
Keep in mind, the 600 also does DV too almost bit-for-bit like a Canopus (DV is a fixed format). That's why I don't have, or care for, my ADVC110 any more.
I have compared DV to a direct high bitrate MPEG-2 capture and found very little difference overall. In fact, some scenes in MPEG-2 looked better such as strong reds/blues or grain retention.
I will do some tests and report back.
On the advice of Jagabo and Vaporeon800 it's best to use something like VirtualDub to get a true-to-form picture. (VideoReDo seems to deinterlace or blur it somewhat.)Originally Posted by dorenhagen
MPEG Source -> D2V -> AVS -> Load into VDub -> Slider and F3/F4 to Mark In/Out one frame of choice -> File -> Save image sequence... -> enter your settings (I prefer BMP) -> OK
Then you can use something like Windows Paint to convert to PNG (since this forum doesn't accept BMP and PNG is better than JPG for this).Last edited by PuzZLeR; 25th Feb 2011 at 21:15.
Puzzler, I just used MPEG Video Wizard to compare AVI captures from the Canopus, the MPEG-2 conversions of those Canopus captures and the MPEG-2 direct captures by a Magnavox DVD Recorder from Walmart.
MPEG Video Wizard was far less than ideal for the task but one thing was clearly evident. The direct captures from the Magnavox DVD Recorder were unquestionably sharper with more detail than the either the direct Canopus AVI capture or the MPEG-2 from the re-encode from the Canopus. I have to admit this was quite surprising. Later, if I can figure out VirtualDub I will get some captures from all three files and see how they compare.
Very interesting!! I just hope the direct capture with the AVI USB device is as good. Then all this will have been worth it. I will keep you posted. My new HD arrives Monday and I hope to be capturing soon afterward.Last edited by dorenhagen; 25th Feb 2011 at 23:19.
Use VirtualDubMod when dealing with MPEG 2 files. It has a built in MPEG 2 reader and handles interlaced MPEG 2 correctly.
1) File -> Open Video File
2) seek to the frame you want
3) Video -> Snapshot Source Frame, use PNG -
Let me also highly suggest, if you haven't already, that you learn some basic AviSynth as well - you will miss out on so much in this hobby without it.
For one example, instead of Womble, a much better way to compare two video clips frame-by-frame is with Interleave() using AviSynth. It has saved me much time over the years making an effective decision during testing instead of squinting on playback.
An excellent tool that makes it easy to start is AvsP. It's free and needs no installation. Once you set up your first script that previews correctly you will be fine after that.
EDIT: Just remembered that AvsP is recently discontinued and replaced by AvsPMod, which is an upgrade.Last edited by PuzZLeR; 26th Feb 2011 at 15:03.
I'm assuming you mean the 500GB HDD will be used for the laptop. It won't work unless suitable Windows XP device drivers are available for your laptop. I hear that is sometimes the case. If Windows XP is not an OS option made available for a laptop, it stands to reason that some makers wouldn't bother to have XP drivers written for it. If so, you may need to reconsider getting a used PC for running XP as suggested by PuzZLeR .
Looking for capture device, is this what I need?
By V Bot in forum Capturing and VCRReplies: 3Last Post: 21st Apr 2012, 10:16 -
Capture device
By ingeborgdot in forum Capturing and VCRReplies: 7Last Post: 11th Sep 2011, 21:02 -
Capture Device
By NMeade in forum Capturing and VCRReplies: 7Last Post: 24th Feb 2011, 18:23 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
capture device for hd
By jjjamiem in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2007, 15:30
