I was hoping someone on here could help me with a little situation i'm having with tsMuxer.
So, i buy a BD and immediately go to put it on my Linux server for viewing throughout my apt. I rip the BD and then convert using Ripbot. Once I have the MKV for the movie, I use tsMuxer to demux the .SUP files and then MKVmerge to merge the two into MKV. I do not convert the .SUPs to anything (like .sub) before merging. Boxee Box plays the MKV with SUP very well.
My issues is that with the new Toy Story 3 BD, the main movie is broken into multiple files (15+). I pull the .mpls file into tsmuxer and it brings in all the appropriate files to create a large file (i have successfully done this with other movies that were comprised of 5-10 files). The issue is that tsMuxer names the file "0005+00012+..." etc for each file that comprises the playlist. The problem is the file name is too long for tsMuxer to create a .SUP file since it is 15+ files. Any idea how to fix this? Any other way to obtain the .SUP file than from tsMuxer? Thanks.
tsMuxer and joining m2ts files
By fkasparek in forum Blu-ray RippingReplies: 13Last Post: 12th Jun 2014, 13:07 -
can tsmuxer change h.264 mov to m2ts files without reencoding?
By Onceler2 in forum Video ConversionReplies: 2Last Post: 20th Mar 2012, 05:47 -
I can not add .m2ts files into TSMuxer
By yaoyao0204 in forum Blu-ray RippingReplies: 2Last Post: 25th Nov 2011, 21:00 -
Does multiavchd or tsmuxer support .tp files as input sources?
By yoda313 in forum Video ConversionReplies: 8Last Post: 8th May 2010, 09:08 -
Audio drifting when merging Sony .m2ts files in tsMuxeR
By jaholmes in forum Authoring (Blu-ray)Replies: 2Last Post: 28th Sep 2009, 13:02
