    Feb 2011
    Canada
    Hi there.. I'm having a slight issue with some mp4 files playing on my PS3. It seems around 20% of the Mp4's show "corrupted data" when played on the ps3, while others play just fine. I'm looking to convert these files into a known good format, however, I'm having trouble finding a codec that is going to work for me.
    I'm using program called MediaInfo (http://mediainfo.sourceforge.net/en) to help find the differences between an mp4 that works, and one that does not. From what I can tell, these files look really close, but perhaps someone could look at this information and show me what the big differences are. Thank you in advance..
    Working File:
    General
    Complete name                    : \\solaris\c$\Movies\Pandorum (2009)\Pandorum (2004).mp4
    Format                           : MPEG-4
    Format profile                   : Base Media
    Codec ID                         : isom
    File size                        : 1.60 GiB
    Duration                         : 1h 47mn
    Overall bit rate                 : 2 125 Kbps
    Encoded date                     : UTC 2010-02-07 07:39:32
    Tagged date                      : UTC 2010-02-07 07:39:32
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : Main@L4.1
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 6 frames
    Codec ID                         : avc1
    Codec ID/Info                    : Advanced Video Coding
    Duration                         : 1h 47mn
    Bit rate mode                    : Variable
    Bit rate                         : 1 703 Kbps
    Maximum bit rate                 : 20.5 Mbps
    Width                            : 1 280 pixels
    Height                           : 544 pixels
    Display aspect ratio             : 2.35:1
    Frame rate mode                  : Constant
    Frame rate                       : 24.000 fps
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.102
    Stream size                      : 1.28 GiB (80%)
    Writing library                  : x264 core 80 r1376M 3feaec2
    Encoding settings                : cabac=1 / ref=6 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.2 / mixed_ref=1 / me_range=26 /
    chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 /
    constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=50 /
    rc=2pass / mbtree=1 / bitrate=1703 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 /
    ip_ratio=1.40 / aq=1:1.00
    Encoded date                     : UTC 2010-02-06 20:34:09
    Tagged date                      : UTC 2010-02-07 07:40:56
    Audio #1
    Format                           : AAC
    Format/Info                      : Advanced Audio Codec
    Format profile                   : LC
    Codec ID                         : 40
    Duration                         : 1h 47mn
    Bit rate                         : 288 Kbps
    Maximum bit rate                 : 386 Kbps
    Channel(s)                       : 6 channels
    Channel positions                : Front: L C R, Side: L R, LFE
    Sampling rate                    : 48.0 KHz
    Compression mode                 : Lossy
    Stream size                      : 224 MiB (14%)
    Language                         : English
    Encoded date                     : UTC 2010-02-07 07:40:24
    Audio #2
    Format                           : AAC
    Format profile                   : LC
    Codec ID                         : 40
    Duration                         : 1h 47mn
    Bit rate                         : 127 Kbps
    Maximum bit rate                 : 166 Kbps
    Channel(s)                       : 2 channels
    Channel positions                : Front: L R
    Stream size                      : 98.0 MiB (6%)
    Language                         : English
    Encoded date                     : UTC 2010-02-07 07:40:52
    Non Working File
    General
    Complete name                    : \\SOLARIS\d$\Movies\Alice in Wonderland (2010)\Alice in Wonderland
    (2010).mp4
    Format                           : MPEG-4
    Codec ID                         : isom
    File size                        : 2.18 GiB
    Duration                         : 1h 48mn
    Overall bit rate                 : 2 875 Kbps
    Encoded date                     : UTC 2010-05-13 20:12:22
    Tagged date                      : UTC 2010-05-13 20:12:22
    Video
    Format                           : AVC
    Format profile                   : High@L4.1
    Format settings, ReFrames        : 8 frames
    Codec ID                         : avc1
    Duration                         : 1h 48mn
    Bit rate                         : 2 552 Kbps
    Maximum bit rate                 : 14.1 Mbps
    Height                           : 720 pixels
    Display aspect ratio             : 16:9
    Frame rate                       : 23.976 fps
    Color space                      : YUV
    Bit depth                        : 8 bits
    Bits/(Pixel*Frame)               : 0.115
    Stream size                      : 1.94 GiB (89%)
    Title                            : Alice in Wonderland By 3Li
    Encoding settings                : cabac=1 / ref=8 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh /
    subme=9 / psy=1 / psy_rd=0.2:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 /
    cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-1 / threads=3 / sliced_threads=0 / slices=2
    / nr=0 / decimate=0 / mbaff=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 /
    direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=42 / rc_lookahead=42 / rc=2pass
    / mbtree=1 / bitrate=2552 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0
    / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Encoded date                     : UTC 2010-05-13 03:07:15
    Tagged date                      : UTC 2010-05-13 20:12:59
    Audio
    Format                           : AAC
    Format profile                   : LC
    Codec ID                         : 40
    Duration                         : 1h 48mn
    Bit rate                         : 320 Kbps
    Maximum bit rate                 : 342 Kbps
    Stream size                      : 248 MiB (11%)
    Language                         : English
    Encoded date                     : UTC 2010-05-13 20:12:54
    Feb 2011
    Canada
    Looks like this thread is irrelevant now.. I've found a software called Handbreak that allows me to convert these files to mp4's that play perfectly on the ps3..
  3. 8 ReFrames and 6 bframes is probably too much for the PS3.
    Feb 2011
    Canada
    @jagabo
    Thanks very much for the reply..
    I'm not 100% sure what the reframes and bframes are at the moment, however, I look forward to doing some research on the matter.
    Thanks again.
  5. Bframes are bi-directionally encoded frames -- pieces can come from frames both before and after the bframe. As opposed to P frames which can only reference prior frames; and I frames which are individual pictures like a JPEG image.
    http://mewiki.project357.com/wiki/X264_Settings#bframes
    ReFrames, or reference frames, are the number of different frames those pieces can come from.
    http://mewiki.project357.com/wiki/X264_Settings#ref
