Hi.
I'm looking for a tool to demux my DVB-S transport stream file.
So far, I used Project.X (old - 2006) and PVAstrumento (even older!), but Project.X doesn't like new Java versions too much.
Anything else out there which might do a similar job?
Thanks,
I use projectx for mpeg2 files and works flawlessly, it hasn''t been updated for avc/h.264 streams I assume that's what your talking about
if so try tsdemux or tsmuxer.
There's more here: https://www.videohelp.com/tools/sections/video-de-multiplexers -
You can get the latest build here
http://www.watchersnet.de/Downloads/tabid/53/rrcid/2/rrscid/8/rreid/345/rrpid/1/rrepp/...0/Default.aspx
It would also be helpful if you posted the text log file from MediaInfo - this would help in diagnosis.
Also is you system 32bit or 64bit ?SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
I forgot to mention ...
It's for MPEG-2 demux.
It's for a 16 bit machine.
It was compiled for java 1.3.0.
Now I use 1.6 jre and this probably generates the errors.
BTW ... the errors are sporadic. I tried to copy/paste one here now, but the file generating this morning went through flawlessly right now. -
I'm using java 1.6 latest build and all is fine, use the java to run on java for any vsn of windows
I guess you can use the exe... -
Latest version of PVAStrumento is v2.1.0.22 released on the 2009-03-15 which is not that old
Official page here: http://www.offeryn.de/pvas_2_1.htm
Although be aware that the default settings are very agressive and may lead to the loss of many GOP's so you may want to tweak some of the settings of the Expert tab.
For ProjectX I'm using the v0.90.04.00.b32 build from this page http://www.oozoon.de/main_en.html which is working pretty fine with latest Java 1.6.0 build 23 as of today. -
My god ... SORRY! a 32 bit of course !!!
Windows XP SP3.
BTW ... the error reappeared.
@BazilCode:!> an error has occured.. (please inform the authors at 'forum.dvbtechnics.info') java.lang.ClassCastException: sun.java2d.NullSurfaceData cannot be cast to sun.java2d.d3d.D3DSurfaceData at sun.java2d.d3d.D3DRenderer.copyArea(Unknown Source) at sun.java2d.d3d.D3DSurfaceData.copyArea(Unknown Source) at sun.java2d.SunGraphics2D.doCopyArea(Unknown Source) at sun.java2d.SunGraphics2D.copyArea(Unknown Source) at javax.swing.BufferStrategyPaintManager.copyArea(Unknown Source) at javax.swing.RepaintManager.copyArea(Unknown Source) at javax.swing.JViewport.blitDoubleBuffered(Unknown Source) at javax.swing.JViewport.windowBlitPaint(Unknown Source) at javax.swing.JViewport.setViewPosition(Unknown Source) at javax.swing.plaf.basic.BasicScrollPaneUI$Handler.vsbStateChanged(Unknown Source) at javax.swing.plaf.basic.BasicScrollPaneUI$Handler.stateChanged(Unknown Source) at javax.swing.DefaultBoundedRangeModel.fireStateChanged(Unknown Source) at javax.swing.DefaultBoundedRangeModel.setRangeProperties(Unknown Source) at javax.swing.JScrollBar.setValues(Unknown Source) at javax.swing.plaf.basic.BasicScrollPaneUI.syncScrollPaneWithViewport(Unknown Source) at javax.swing.plaf.basic.BasicScrollPaneUI$Handler.viewportStateChanged(Unknown Source) at javax.swing.plaf.basic.BasicScrollPaneUI$Handler.stateChanged(Unknown Source) at javax.swing.JViewport.fireStateChanged(Unknown Source) at javax.swing.JViewport.setViewPosition(Unknown Source) at net.sourceforge.dvb.projectx.gui.ProcessWindow.setMessage(ProcessWindow.java:979) at net.sourceforge.dvb.projectx.gui.GuiInterfaceImpl.setMessage(GuiInterfaceImpl.java:225) at net.sourceforge.dvb.projectx.common.GuiInterface.setMessage(GuiInterface.java:212) at net.sourceforge.dvb.projectx.common.Common.setMessage(Common.java:1095) at net.sourceforge.dvb.projectx.common.Common.setMessage(Common.java:1049) at net.sourceforge.dvb.projectx.common.Common.setMessage(Common.java:1038) at net.sourceforge.dvb.projectx.parser.StreamParserTS.parseStream(StreamParserTS.java:1054) at net.sourceforge.dvb.projectx.parser.StreamParser.parseStream(StreamParser.java:92) at net.sourceforge.dvb.projectx.parser.MainProcess.processCollection(MainProcess.java:954) at net.sourceforge.dvb.projectx.parser.MainProcess.startProcessing(MainProcess.java:366) at net.sourceforge.dvb.projectx.parser.MainProcess.run(MainProcess.java:151)
Thanks a lot. Works fine with 1.6.0 / 22.Last edited by geohei; 15th Feb 2011 at 09:00.
Open source TS mux/demux tool
By rrrip in forum Video ConversionReplies: 1Last Post: 28th Jan 2012, 09:39 -
Demux/Mux Tool
By mltwitz in forum DVD RippingReplies: 3Last Post: 7th Dec 2010, 10:39 -
Trying to mux / demux
By GLE3 in forum Newbie / General discussionsReplies: 2Last Post: 18th Dec 2009, 12:07 -
How to demux
By php111 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Aug 2007, 18:07 -
ProjectX demux help
By delpis in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2007, 01:51
