I'm working on wanting to upload video to youtube and my website. I am using my DVD recorder to download into MPEG Streamclip so that I can convert to an avi file to put into Windows movie maker.
I've done this before with no problems, but it's been a few years since I've done this and I don't know if I'm missing a step somewhere.
From what I recall...
I open the VTS_01_1 file.
I fix the timecode breaks.
Do any cutting and trimming.
Then I click to export to AVI
Set compression to Apple DV-PAL
Change the frame size.,
then click "Make AVI"
Like I said, as far as I remember this seemed to work fine. But now, I keep getting an error that says it can't create the AVI file. In fact, it won't let me create any type of file, MPEG or otherwise. So, I don't know if I'm missing a step or what.
Anybody have any ideas?
Where are you trying to save the AVI file? Not on the (closed) DVD disc, I hope...
Maybe try a different location, on your hard disk. -
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 11:31 -
MPEG Streamclip / Converted WMV to MPEG-4 but only got the audio? Help me.
By aka_director in forum Video ConversionReplies: 0Last Post: 3rd Oct 2010, 22:24 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
