    Feb 2011
    Los Angeles, CA
    Here is the log. Any hints? I notice that when I try to play or preview the source, it's spotty and gray. Source plays fine in VLC, MPEG Streamclip, and Quicktime. It was encoded using the "Normal" setting of Handbrake.
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Sat Feb 12 17:30:04 PST 2011
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    Seems that stream 0 comes from film source: 90000.00 (90000/1) -> 36.00 (36/1)
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/Data/DVD archive/LittlePim 2-1.m4v':
    Duration: 00:05:02.7, start: 0.000000, bitrate: 878 kb/s
    Stream #0.0(und), 36.00 fps(r): Video: h264, yuv420p, 720x480
    Stream #0.1(und): Audio: aac, 48000 Hz, stereo
    Output #0, flv, to '/Volumes/Data/DVD archive/LittlePim 2-1.m4v.ff.flv':
    Stream #0.0, 12.00 fps(c): Video: flv, yuv420p, 320x240, q=2-9, 200 kb/s
    Stream #0.1: Audio: mp3, 22050 Hz, stereo, 56 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    Stream #0.1 -> #0.1
    [h264 @ 0x45a630]abs_diff_pic_num overflow
    [h264 @ 0x45a630]decode_slice_header error
    [h264 @ 0x45a630]concealing 1350 DC, 1350 AC, 1350 MV errors
    [h264 @ 0x45a630]illegal short term buffer state detected
    this goes on and on and on for pages ...
    until the very end
    video:2827kB audio:2069kB global headers:0kB muxing overhead 4.857831%
    bench: utime=109.244s
    /bin/sh: /Applications/ffmpegX.app//Contents/Resources/flvtool2: /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/bin/ruby: bad interpreter: No such file or directory
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    I'm not sure why ffmpeg doesn't like the H.264 video stream. It may have to do with the age of this version of ffmpeg in ffmpegX, as ffmpeg has seen a few revisions since, with improvements in handling of H.264 video.
    Alternatives:
    - ffmpeg command line (build your own (e.g. through MacPorts) or 'borrow' a compiled version from some recent app that has ffmpeg in its package)
    - Convert a copy to .mp4 (lower specs) with Handbrake/QuickTime/MPEG Streamclip/whatever, as H.264/AAC .mp4 is compatible with web Flash players, too. [Recommended]
