I am having trouble playing back a recorded .TS file in anything but VLC
In both Winamp & Windows Media Player the recorded file plays back Video only no sound , I have installed FFDshow but it does not seem to fix the problem
Here is what Mediainfo says about the file
Duration : 1h 8mn
Overall bit rate : 4 632 Kbps
Video
Menu ID : 17662 (0x44FE)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 1h 8mn
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AAC
Format profile : LC
Muxing mode : LATM
Codec ID : 17
Duration : 1h 8mn
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -761ms
Language : English
any body got any ideas as I'm stuck
Try haali media splitter. If you are running windows 7 you might have to use Preferred Filter Tweaker so ffdshow will be used in wmp.
thanks for your reply I have installed haali media splitter but the problem still persists , I am running Vista if that helps at all
AAC 5.1 playback on home theater receiver problem
By Phat J in forum Media Center PC / MediaCentersReplies: 5Last Post: 30th Jul 2013, 02:45 -
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 21:59 -
How will an MP3 audio file will compare with a AAC audio file?
By ConverterCrazy in forum AudioReplies: 6Last Post: 31st May 2011, 02:01 -
Problems with playback of AAC audio
By strontium_99 in forum Software PlayingReplies: 3Last Post: 6th Feb 2011, 08:40 -
AAC 5.1 playback problem
By TigerShark in forum AudioReplies: 0Last Post: 30th Sep 2007, 10:08
