    Mar 2004
    Long Island NY
    How can someone achieve a 1080p quality rip at only 1.17 GB? I've copied all the info from MediaInfo. If everything looks correct, then why are there files out there 5x the size with the same quality?
    Format : Matroska
    File size : 1.17 GiB
    Duration : 1h 31mn
    Overall bit rate : 1 837 Kbps
    Movie name :
    Encoded date : UTC 2011-02-10 14:46:41
    Writing application : mkvmerge v3.4.0 ('Rapunzel') built on May 15 2010 09:38:20
    Writing library : libebml v0.8.0 + libmatroska v0.9.0
    Video
    Format : AVC
    Format profile : High@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 16 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 31mn
    Nominal bit rate : 1 639 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.033
    Title : Track01
    Writing library : x264 core 79 r1342kMod e8501ef
    Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=tesa / subme=10 / psy=1 / psy_rd=1.0:0.2 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-3 / threads=3 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=4 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=1639 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Codec ID : A_AAC
    Duration : 1h 31mn
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Title : 5.1 AAC
    Language : English
    Text
    Format : UTF-8
    Codec ID : S_TEXT/UTF8
    Codec ID/Info : UTF-8 Plain Text
    Language : English
    I doubt it look good. If it doesn't contain lots of motion it might look decent.
  3. Same quality? Not a chance. If that 1,639 kbps AVC is correct, and resolution and runtime are correct, it's gotta look like crap.
    [EDIT] Beat me again! Okay, if it's something like "Sunrise Earth" with no camera movement at all and scene cuts only every few minutes, plus you're viewing on a smallish screen, maybe it will look acceptable.
    Pull! Bang! Darn!
    Mar 2004
    Long Island NY
    I'm not sure of the rules if I'm allowed to state the title of the film but actually looks very good. Viewed on a 720p Panny 50" plasma and a 1080P Toshiba 32". BTW, it's an action movie.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Without long samples it's useless to discuss....but if it's a commercial movie then you can't post any samples.
