  1. Hi guys,
    We are building a custom computer for a user at our office and we are going to also need some basic video editing. Mostly, they take a dvd, convert it in windows movie maker, maybe do some splicing and minor edits, then put it back on a dvd.
    We are looking for something faster than windows movie maker (though maybe its just cause they were using a crappy computer that conversion times were slow).
    Also, a side question: "Can dvd material be edited and left in the same format, rather than having to convert it, then edit it, then convert it back? If not, why not?" Thanks!!
    Yep, with for example Mpeg Video Wizard DVD. It will only reconvert over the transitions if you use any then.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Yes...but it is done WITHOUT Windows Movie Maker.....just to clarify Baldrick's post.
  4. Awesome. So any suggestions on some basic software . The selling points for us are:
    1) Fast conversions (or no conversion if we can do all the basic editing and splicing without it)
    2) Simple Editing
    Jan 2007
    Republic of Texas
    2) Simple Editing
    Baldrick already suggested MPEG Video Wizard DVD. That's the most suitable fit for what you have specified.
  6. Thanks guys I saw it the first time then I forgot about the link lol
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    If you don't like Mpeg Video Wizard you can try latest TMPGEnc Video Mastering Works
    Jun 2005
    Vermont
    Just remember, if you use MPEG VIDEO WIZARD (which I do) you have to capture your footage in MPEG format. I have been producing a weekly program for the last couple of years for Public Access TV using MPEG VIDEO WIZARD and have been very happy with the results.
