I'm trying to convert a YouTube video to MP4 so it can be used in iTunes. I'm using Any Video Converter Pro, and I have done this with countless videos without issue. However, with this particular video, the audio seems fine but the video plays as if it's being fast forwarded after I convert it. I assume it's a framerate problem, but I don't know much about framerate or how to fix it. When I add the file to AVC for conversion, it says 60 in the FPS column. When I edit the conversion settings, I can't make the framerate higher than 30. Any suggestions?
I hope this is what you're talking about:
General
Complete name : C:\Users\Admin\Videos\RealPlayer Downloads\General Hospital - Sonny Jason Fight About Emily.flv
Format : Flash Video
File size : 2.25 MiB
Duration : 59s 536ms
Overall bit rate : 317 Kbps
httphostheader : v3.cache4.c.youtube.com
Video
Format : AVC
Format profile : Main@L1.3
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : 7
Duration : 59s 30ms
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.934 fps
Original frame rate : 29.917 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Audio
Format : AAC
Format profile : LC
Codec ID : 10
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 44.1 KHz
Compression mode : Lossy -
I don't think it liked the 29.917 FR. I'll upload the mp4 I created or you can do it yourself download flv extract it will extract the video and audio then add the avc/h.264 video and adts(aac) audio in mymp4boxgui in other words you will extract the files inside flv container and repackage then inside an mp4. This method doesn't require encoding so it's lossless, because your file is avc/h.264 and aac iit's compatible with mp4/mkv.
problem on captured VHS frames
By stefangs in forum Capturing and VCRReplies: 13Last Post: 5th Mar 2012, 01:38 -
Hauppauge capturing frames problem
By richiexd in forum Capturing and VCRReplies: 4Last Post: 18th Jan 2012, 21:18 -
AVI Problem - Skipping Frames
By gonwk in forum Newbie / General discussionsReplies: 4Last Post: 4th Dec 2011, 13:43 -
Problem with some captured frames
By bmbsa in forum Capturing and VCRReplies: 3Last Post: 24th Aug 2008, 20:33 -
Problem Fixing corrupted frames
By Blå_Mocka in forum Newbie / General discussionsReplies: 6Last Post: 13th Nov 2007, 08:44
