I have a bunch of .avi files from DV tapes. I used a Bulk Rename Utility to rename them using the date and time, but also want to incorp the video length in the file name. Is there such a tool available?
http://www.1-4a.com/rename is a pretty good free batch renaming tool. It can do size or length(?) among lots of other features. Not sure if it's exactly what you want...
Scott -
Thx for the suggestion. Looks like this tool can use the length of the filename as a parameter, but I was looking for length of the video.
So for example, I have a file that is 4 min and 2 seconds long and is named "2006-03-09 16.31.03.avi". It would be renamed "2006-03-09 16.31.03 4-02.avi".
I may need to search for a .dll usable in .NET environment that can access a video file's params and write the code myself. My google searches have turned up empty so far.
Any software to rename file based on video properties? good question!
By thomseye in forum Newbie / General discussionsReplies: 10Last Post: 18th Oct 2012, 18:07 -
Tool to batch download, save and rename QuickTime stream files
By oediv in forum Video Streaming DownloadingReplies: 8Last Post: 24th Dec 2011, 18:24 -
Help Rename Title !
By bk_mutante in forum AudioReplies: 0Last Post: 19th Dec 2011, 22:52 -
How to rename a file when it is in ntfs mode
By mysts in forum ComputerReplies: 3Last Post: 19th Feb 2010, 05:34 -
ProjectX - rename source
By epsidol in forum ComputerReplies: 2Last Post: 4th Jul 2007, 00:19
