I have converted a movie ( Jurassic park 3 ) from avi to mpeg with tmpgenc, the audio starts in sync but by the end of the movie it is a few seconds out. The original divx avi is fine, sound in sync throughout, but when converted to mpeg I get the same result every time. It is no good time shifting the audio because as I said, it starts in sync. I've tried ripping the sound first with audio dub, and I've tried it without ripping sound in advance. The result is the same. I'm new to all this and would appreciate any help given.
Thanks in advance
Kevlar69
i would suggest searching for "sound sync progressive" ... it's one of the gotcha problems with conversions and fairly common .... basicly what has probly happened is that your sound is not the same legenth as your video ... i belive their was a guid out their for a program called aviinfo .... basicly you pobly need to adjust the size of your wav file ( cool edit is good for this ) ... sorry i dont have a url that points to a guide ... but aviinfo can be found http://www.chizzil.com/softdetail.cfm?ID=837
Thanks for the reply, but I can't see how the audio can be a different length, it isn't in the dowloaded avi, fully in sync throughout.
thanks for the link, I'll read up on it.
Kevlar69 -
Try using different version of DVD2AVI. I have audio sync problems with all newer versions beyond the original 1.76., when using "FORCE FILM".
Avi to DVD - audio goes progressively more out of Sync
By UnknownVT in forum Video ConversionReplies: 9Last Post: 11th Jan 2012, 13:33 -
Audio goes progressively out of sync. Calculate the "rate of change"?
By rayden54 in forum AudioReplies: 1Last Post: 26th Sep 2010, 07:48 -
Captured video/audio progressively out of sync (on linux)
By daytooner in forum Video Streaming DownloadingReplies: 2Last Post: 25th Nov 2009, 23:26 -
Sound out of Sync in conversion
By opala in forum Video ConversionReplies: 2Last Post: 17th Apr 2009, 19:15 -
riverpast rm to avi conversion sound out of sync
By princevegetam in forum Video ConversionReplies: 9Last Post: 2nd Jul 2007, 02:45
