Hi,
I am trying to burn a bluray disc using a BDMV folder but without certificate folder.The resulting burn is unrecognised by my standalone Panasonic bluray player saying its an unsupported format.
The BDMV folder has four subfolders namely BACKUP, CLIPINF, PLAYLIST , STREAM
Please advise.
This is c/p from doom9's site under decrypting. This poster states:
The CERTIFICATE folder should always exist on a bluray whether empty or not
If the disc contains BD-J (JAR files) and they are signed, then there needs to be a certificate in that folder that authenticates the signature of the JAR files
If the JAR files are not signed, there is no need for a certificate, but BD-J then cannot access some privileged functions, among them access to persistent storage or access to the internet
If the certificates are removed and a signed JAR file wants to access privileged code, the disc simply will not play
If BD-Live content is downloaded from the internet, it may (usually is) signed too, requiring a certificate in that very folder to ensure, that the downloaded content can't be tampered with
That's all there is to it.
And no, there are no keys in that folder and no, the certificates don't cost a penny, the authorers are free to create their own.
What costs money, is AACS and that is a different playground.
Hope that clears it up for you.MovieWatcher666 -
Hi,
Thanks fo the comments. I solved the certficate folder issue.I used another Certficate folder and simply burned it along with the BDMV to get the disc to play the movie on my standalone Panasonic player.But there is a different issue I am facing right now. I ripped one of my original blurays to my PC and want to burn a backup Dual layer disc. The folder structure I got is as follows:
BDMV - AUXDATA (its empty), BACKUP( BDJO,CLIPINF,PLAYLIST,index.bdmv, Movieobject.bdmv), BDJO (its empty), CLIPINF (clpi files),JAR (its empty) META (three folder DL, ES, TN - all empty) PLAYLIST (mpls files) STREAM (m2ts files), index.bdmv, Movieobject.bdmv and the CERTIFICATE FIOLDER
When I am trying to play this file on PowerDVD 7.3 the OK button is not accessible although with other Bluray backups there are only four folders namely BACKUP( CLIPINF,PLAYLIST,index.bdmv, Movieobject.bdmv),CLIPINF (clpi files),PLAYLIST (mpls files) STREAM (m2ts files) along with index.bdmv, Movieobject.bdmv and the CERTIFICATE FOLDER and they play fine with PowerDVD.
I am not sure whether I should use the 8 folder or the 4 folder structure to burn the bluray as I have had a few unplayable discs considering the high cost of the blanks. Please let me know a compliant file structure which will be accepted by a standalone player.
Thanks -
I have one problem with PANASONIC BD-35 when I modify a .jar file.
For example, the text of "audios" for audio selection of the movie. When I playback the BD, it works well, but when I show the menu all text of the modified .jar file not appears (it's empty).
When I playback in the PC or another Blu-ray reproducer (I tested it in Samsung) works well and I can see the new texts in the menu of the modified .jar file.
I have read by Internet that this is a concrete problem of four models of PANASONIC (included my BD-35), and that the solution is, after modified .jar fiel, re-sign it.
And this is my problem, I don't know how to resign the modified .jar files.
It's exists one tuturial that says about to make a ISO of the blu-ray folder, insert the ISO in DAEMON TOOLS and decrypt it again with AnyDVD HD. (versions previous to 6.8.0.0 because 6.8.0.0 doesn't fix java in unprotected discs anymore) .
I tried it and AnyDVD not make new CERTIFICATE content (it keeps the same) and .jar files are not re-signed.
¿Can you help me?
Thanks a lot.
Burning BluRay Problem!
By benhur57 in forum Blu-ray RippingReplies: 2Last Post: 6th Apr 2012, 11:40 -
Newbie Question on Burning Bluray
By discover in forum Newbie / General discussionsReplies: 5Last Post: 23rd Feb 2012, 15:35 -
Burning a bluray but no sound..
By malmsteen in forum Video ConversionReplies: 9Last Post: 19th Feb 2012, 17:16 -
burning ripped bluray?
By tomrip in forum Blu-ray RippingReplies: 3Last Post: 14th Feb 2009, 23:32 -
Burning HD Video to BluRay
By frogger0528 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 25th Nov 2007, 13:07
