Trying to encode this AVI source video file which is in sync, but when converting to DVD (mpeg-2), the movie goes out of sync.
I used the audio gap feature in the TMPGenc Authoring Works 4 and it seemed to correct the problem but only in the first 25 minutes of the movie, then it goes out of sync again as if the sync delays are different in selective parts of the movie.
I know the original AVI was perfectly in sync, and I also know my other mpeg2 encoded files worked fine but every now and then I seem to get this issue and was wondering if this has something to do with the build frames inside the avi structure?
Was thinking it might be the framerate but I've converted 25fps -> 29.976fps all the time. Would and could try another program but I doubt its the program as I explained earlier it only happens on a very few avi files, any help is appreciated.
Try recoding the audio using virtualdub. Set the video to "direct copy" and audio to "full processing mode".
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 12:07 -
HDTV makes DVD movie look "less" like a movie?
By breakchange in forum DVB / IPTVReplies: 73Last Post: 6th Oct 2011, 09:28 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2011, 23:16 -
Audio drifting out slowly - Gradually goes OOS.
By blackflames in forum AudioReplies: 23Last Post: 10th Jun 2010, 05:02 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 11:33
