I need to convert a dvd to xvid avi with the best quality for a file size of 900mb i was using Autogk For a While but the results i am getting now are not great the dark colored areas in the movies are visibly
distorted i have tried other programs but the only size i can get good quality is 2gb and that is way to big ineed it to be avi cause it has to play on a ps3
please help
A long(er) movie will look worse than a shorter movie simply because there is more data to compress. It doesn't matter what your final output size is...the input size also matters. Your question is un-answerable.
then let revise my question what is the best quality setting but not killing hard space to much
what is the best settings for any particular length of movie as movies vary in length but somebody must have have at least a rule of thumb guide to go by
What's the length of your movie? If AutoGK won't work, maybe you want to give Xmedia Recode a try. It comes with presets for all kinds of devices.
Rule of thumb? I can say that Xvid looks quite good with 900+ kbps, h264 with 700+ kbps. This goes for movies with DVD res (720x576). Don't know about 720p or even 1080p... -
Rule of thumb: forget bitrate, use constant quality encoding. Dark areas are one of Xvid's weak spots. Be sure the black levels of your display are set properly so dark areas really dark. If your graphics card and monitor are displaying blacks as dark gray all the problems in the dark areas will be more noticeable.
Bullsh*t.
The PS3 can play much more than AVI files. If you must keep it at the (arbitrary) size of 900MB I suggest you use XmediaRecode and encode with a 2-pass VBR H264 compression into an MP4 container. Use the PS3 preset and tailor it from there, You will get far better quality than Xvid can produce, and the PS3 will play it without any problems.Read my blog here.
Convert .vob to another format with max quality
By alexv305 in forum DVD RippingReplies: 7Last Post: 19th Jun 2010, 22:36 -
Looking to convert avi ( xvid ) to decent quality flv videos
By mordor in forum Video ConversionReplies: 0Last Post: 26th Oct 2009, 02:56 -
Best way (meaning quality and 700MB size) to convert a DVD to a Xvid?
By riahc3 in forum DVD RippingReplies: 24Last Post: 7th Jun 2009, 16:59 -
Difference in size when using two different prograns to convert XVid to DVD
By perfection in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2008, 12:43 -
Best way to convert a video to iPod with max quality and min filesize
By Salva Veritate in forum Video ConversionReplies: 1Last Post: 4th Jan 2008, 10:34
