In Premiere Pro (regrettably I only have CS3.2) what are the preferred file-export movie-settings in order to yield the best possible result? Visual quality is king, hard drive space used is not a real concern.
What choices and codecs did you make and why?
I have Cineforms Neoscene along with Matrox’s and Avids free codecs to work with.
Anything else I should be considering?
Would you care to share your settings too?
Just as importantly, how did or would the resulting product visually compare with the same project timelines contents rendered/compressed/processed with Adobe media encoder to either a .ts,/.m2t,/.mpeg or an h.264 file?
I’m trying to determine my options are.
Which does a better job in you experience:
a) Adobe Media Encoder or:
b) Through the Export Movie/settings module?
Thanks so much for participating.
Results 1 to 1 of 1
Need to export movie in Premiere Pro 1.5. What settings?
By vid83 in forum EditingReplies: 5Last Post: 23rd Mar 2013, 17:13 -
Optimal Settings to export HD Video with 5.1 from Sony Vegas to a PCH A210
By BeeJayF in forum Newbie / General discussionsReplies: 0Last Post: 18th Mar 2012, 15:53 -
Prem Pro CS 5.5 + Lagarith anyone? et. al.
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 14th Oct 2011, 14:13 -
Youtube video: Premiere pro export and then use Windows Movie Maker?
By vid83 in forum Newbie / General discussionsReplies: 2Last Post: 13th Dec 2007, 21:59 -
Premiere Pro to Encore DVD. Export movie or Encode?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2007, 04:37
