The program that comes with the HD PVR, Total Media Extreme, has settings where you can change sharpness, tint, brightness, contrast, etc. I'm assuming it's supposed to change those settings for the input (what is being shown in the program, when you're ready to capture). I want to make the image a bit sharper, so my captured videos are crisper. The sliders that supposedly change the sharpness and brightness and whatnot do not work at all... the image doesn't change one bit. I tried restarting the program, the Hauppauge, and my computer, but no changes.
Help is appreciated! Thank you!
I'm not 100% sure but I don't think you can change those settings. I believe that what is broadcast is what you get.
Thanks for the quick replies!
That's a shame. I wonder if the bit rate even changed when I set it to 13.5 Mbps a while ago.
Thanks for the help, appreciate it! -
You can definitely change the capture bitrate.
You know, when I read your post I thought "What?! I've had the Hauppauge all this time and didn't know about those options?"
Meant to check on it right then but got sidetracked.
Pull! Bang! Darn!
Hauppauge HD PVR
By Susan_T in forum Video Streaming DownloadingReplies: 1Last Post: 21st Nov 2011, 20:06 -
Hauppauge HD PVR
By Susan_T in forum Newbie / General discussionsReplies: 1Last Post: 21st Nov 2011, 15:20 -
Hauppauge HD PVR capture and jerky video issue
By Split Infinity in forum Capturing and VCRReplies: 0Last Post: 10th Apr 2010, 07:27 -
Hauppauge HD PVR
By karebo in forum DVB / IPTVReplies: 13Last Post: 6th Jun 2009, 08:57 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 09:04
