    Sep 2003
    I am trying to convert a regular DVD film to a avi format that is ca 700 MB in size, but the iSofter DVD Ripper does not seem to comply. I just want a simple program, pop a dvd in my PC, press convert and voila! Any suggestions? What do online rippers use?
    Kal
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    "Pros" don't use one-click programs. Your best bet would be to put out some money for DVDFab or learn to do it step by step with freeware.
  3. Member DB83's Avatar
    Jul 2007
    Well, autogk can create a 700 mb avi from a dvd. But even that if not really a 'one-click' program and I would certainly NEVER even attempt that by just 'inserting dvd in PC' since, basically, it will not work.
    The dvd will need to be ripped to your HDD first. Pure and simple. From there you will need to tweak the settings dependant on the dvd.
    To summarise, there is no 'one-click' solution.
