how can i know if a video is MP4 or MKV.
here is the info i have :
General
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 1.20 GiB
Duration : 2h 32mn
Overall bit rate : 1 127 Kbps
Encoded date : UTC 2010-12-19 03:53:38
Tagged date : UTC 2010-12-19 03:53:38
Video
Format : AVC
Format profile : High@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 2h 31mn
Bit rate mode : Variable
Bit rate : 1 000 Kbps
Maximum bit rate : 2 000 Kbps
Width : 720 pixels
Height : 396 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.117
Stream size : 1.06 GiB (88%)
Language : English
Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics : BT.601-6 525, BT.601-6 625, BT.1358 525, BT.1358 625, BT.1700 NTSC, SMPTE 170M
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 32mn
Bit rate mode : Constant
Bit rate : 127 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 139 MiB (11%)
Language : English
thx
Results 1 to 10 of 10
Both are just containers. You tell the difference either by looking at the file extension (you may have to enable the option "Show file extensions for known file types" under Folder Options to see this), or by opening the file in MediaInfo and looking at the Tree or Text view.
The details you have posted could belong to either.Read my blog here.
the file was originally "labeled" avi
i changed it to mp4 but now im wondering if its an MKV.
just saw that details included work for both containers.
i suppose knowing which type it is doesn't really matter.
ty for your helpLast edited by Leach; 9th Feb 2011 at 03:53.
well i used gspot to make sure it wasnt avi, but that was with version 2.1
this is what i get from gspot 2.70a
isom: MP4 Base Media v1 [IS0 14496-12:2003]
- mp41: MP4 v1 [ISO 14496-1:ch13]
Recommended Display Size: 720 x 396
Created: 2010 Dec 20 05:53:38
Modified: 2010 Dec 20 05:53:38
im going to leave the file @ mp4.
ty gunslinger
edit: i use MPC HC and vlc 0.86 for playing videos -
Format : MPEG-4
then a bit of googling made me think it could be MKV and the fact that i was never able to figure out what isom was didn't help either.
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
MKV Compression to a smaller MKV or MP4
By THRobinson in forum Video ConversionReplies: 9Last Post: 20th Jul 2018, 10:56 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
muxing .264 stream to .mkv, or to .mp4 first, an then to .mkv ?
By codemaster in forum Video ConversionReplies: 2Last Post: 20th Sep 2011, 20:50 -
Issues Converting MKV to MP4 (could be due to damaged MKV header??)
By MohQ in forum Video ConversionReplies: 1Last Post: 1st Feb 2008, 03:10
