    Feb 2011
    Gilbert, Arizona
    Can MJPEG export be added to ffmpegX ?
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Only the developer can add new output formats.
    Yours is the first request for this target format, as far as I can recall. (Most folks want to convert from it, which is already supported.)
  3. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    You can get a (free) conversion to MJPEG with e.g. MPEG Streamclip.
    Menu File > Export to QuickTime > Compression: Apple Motion JPEG A; or
    Menu File > Export to AVI > Compression: Apple Motion JPEG A.
