Tomorrow i'll get mini dv tapes of my cousin's wedding. If they are progressive dv records, can i capture them by progressive mode with my non-progressive camera? Btw, Is there a way to know that tapes are progressive or not?(Of Course, they don't know the camera model) Thanks, Best wishes…
	Progressive DV video is recorded as various field pad (aka telecine) sequences so a straight copy will be output as pseudo 720x480i or 720x576i and will play fine in a similar format DV camcorder. Post a clip with motion so we can try to decode the pattern.
 The camcorder make/model and recording mode would save this CSI work.
 PS: Since you are in Istanbul, it is most likely you will have 720x576i (full interlace) or a 25p mode (both fields sampled at same point in time. An "NTSC" tape will not play in a "PAL" DV camcorder.Last edited by edDV; 8th Feb 2011 at 16:35. Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Thanks for reply, but my real question is : my dv camera can't record 25p mode, however can i capture 25p dv tape by using my camera?
  mini DV tape into computerBy caseyrunning in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2010, 03:42
  how to join Mini DV Cam discs onto 1 large DVD-R?By Debbieengler in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 1st Oct 2009, 16:20
  Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 03:18
  mini dv cam / min focal distance?By kr236rk in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 27th Jul 2008, 10:57
  How should I know my mini dv cam is shooting a true 16:9By joy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 5th Oct 2007, 13:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
