    Nov 2002
    Is there any way that I can change the Nvidia con in the system tray to something that I can see? I've searched the folders but can't find an icon anywhere. There has to be one since it shows up in the system tray but I can't find it.
    Here is a screenshot of the system tray and the icon that I would like to use. I have it blown up to make it easier to see.
    Image Attached Images
  2. Yes its possible but its not simple
    1) Backup c:\windows\system32\nvmctray.dll file
    2) Open c:\windows\system32\nvmctray.dll file in Axialis IconWorkshop Full Mode
    3) Select and change icon 16x16-256
    4) Save modified nvmctray.dll to desktop
    5) Restart and boot to safe mode, copy and replace nvmctray.dll in c:\windows\system32\ folder
  3. DECEASED
    Jun 2009
    Heaven
    Download size = 34.08MB
    OTOH, Resource Hacker occupies less than 1.5MB
  4. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    +1 for resource hacker
    Donadagohvi (Cherokee for "Until we meet again")
    Nov 2002
    I found a program called PS Tray Factory. There is a free version and a 30 day free trial for the $24.95 version.
    Here is the new Nvidia icon...
    Nov 2002
    What all does resource hacker do?
  7. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    http://en.wikipedia.org/wiki/Resource_Hacker
    Resource Hacker (also known as ResHacker or ResHack) is a free resource extraction utility developed by Angus Johnson for Windows. It is used to modify program or operating system elements such as icons by extracting resources from executable program (.exe), program extension (.dll), and resource (.res) files.
    Nov 2002
    Thanks!
