I watch satellite tv through my avermedia hd dvr card....I am getting horizontal flickering artifacts that are usually seen during scenes of high contrast or when there is quick movement in a scene. I'm running the latest drivers for the capture card and my graphics card.
Specs:
Amd Phenom 3 710
Asrock M3A770DE mobo
2 gb ddr3 1600 ram
Radeon 5770
Any ideas?
On all channels? On HD and SD content, or only one type? I assume you are using a SAT box to tune the signal? ...and if so, how is it connected to the PC?
Google is your Friend -
All channels, HD and SD, using a directv sat box h24 which is connected to the card via hdmi cable. No help so far from Avermedia tech support.
I have this same card, and get the same issue when there's fast movement, especially horizontal movement (I watch ESPN all the time and I see it very frequently). I've done a several test captures (just HD channels now that I think about it), and none of those odd horizontal "lines" showed up in any of the actual captures, but there were certainly there in the preview window while recording!
I'm assuming you've already done test captures? ...and those lines are still there for you? unless you already know your captures are clean and you just want to watch tv without those lines...haha sorry if that's the case
I too use a DirecTV HD box, connected via HDMI, capturing in MPEG-2 @ 40Mbps.
Avermedia avertv hd-dvr problem
By ABUELLO in forum DVB / IPTVReplies: 9Last Post: 28th Feb 2012, 23:21 -
AverMedia USB HD-DVR + PS3?(need help)
By Gskyace in forum Capturing and VCRReplies: 2Last Post: 30th Apr 2011, 21:59 -
Hauppague WinTV-HVR-1600 vs Avermedia capture card with SAA7130 chip
By johnnyquid in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2008, 19:29 -
4 port capture card - avermedia lx5004 - not working correctly
By 4dplane in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2007, 21:39 -
Watching multiple streams from a single capture card?
By Drunia in forum Newbie / General discussionsReplies: 11Last Post: 4th Jun 2007, 18:26
