    Feb 2005
    EARTH
    hello
    as shown in this photo:
    my connector is DVI-D single link
    however it is hard to find such cables (probably outdated), so are there any of the other connectors that appear in the photo, compatible with mine?
    thanks
    Oct 2005
    666th portal
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by ecos View Post
    hello...
    thanks
    What are you connecting to what? DVI-D single link is very common.
    A DVI-I connector (as found on computer display cards) usually will feed DVI-D + DVI-A (VGA) pins.
    A DVI-I to HDMI cable will only use the DVI-D single link pins.
    http://www.kiva.org/about
  4. Originally Posted by edDV View Post
    hello...
    thanks
    Having a very similar problem - My laptop has DVI output but only seems to connect to DVI-D (single link).
    I'm trying to connect a laptop to an audio receiver Via HDMI using DVI output from laptop.
    It works with a LCD monitor using DVI-D (single link) but will not work with any other adapter type ie. DVI-A --> VGA or DVI-D (dual link) --> HDMI
    Is this normal? Am I doing something wrong?
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    dvi-d is video only.
  6. Originally Posted by aedipuss View Post
    Sorry, I meant 5.1 AV receiver , it's also hooked up to cable and DVD player.
  7. Member edDV's Avatar
    Mar 2004
    Check the laptop specs.
    If you don't have a digital audio optical or coax connector, you will need to use the headphone jack. Some laptops have dual function headphone jacks that pass optical audio with an adapter like this.
  8. Member edDV's Avatar
    Mar 2004
    hello...
    thanks
    DVI-D to HDMI should work for video. Some late model laptops add audio to DVI-D. You need to read the laptop manual.
