I have a Hauppauge WinTV PVR-150 card. I have satellite with a dvr box. On the box of it it has a off air plug not being used. I'm wondering if i can use the off air plug to capture videos off my dvr box. I don't want to unplug either cable to capture using the capture card.
I'm using windows 7 32bit home premium.
I use a cable splitter off of my DirecTV box straight into my Hauppauge PVR running Windows 7n 32bit. Works great.
If it feels good, do it. -
I don't think i can do that because my one cable going into sat. dish 2 is on a muiti switch and sat 1 cable is from my wall. Last time i tried to splitter with my direct tv box it didn't work at all. I don't want to unplug either one to use the capture card cause my box is set to use both lines. If i disconnect 1 cable my season passes won't tape at the same time.
I think your "off air plug" is an antenna input into the satellite box (to allow it to tune local TV channels), not an output.
I fixed the problem i ran a 3rd cable line into my room for the card now i don't gotta disconnect my dvr cables
capture VHS with Hauppauge PVR 150?
By shun in forum Capturing and VCRReplies: 13Last Post: 24th Jul 2010, 19:11 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39 -
Hauppauge PVR 150 compatibility with my OS
By GangstaRap in forum Capturing and VCRReplies: 11Last Post: 14th Mar 2008, 11:03 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum Capturing and VCRReplies: 10Last Post: 5th Mar 2008, 03:19 -
Hauppauge WinTV PVR-150 ($60) vs. ATI TV Tuner 650 ($100)
By RoganSarine in forum Capturing and VCRReplies: 2Last Post: 13th Dec 2007, 03:48
