Having a video stability issue with my Panasonic DMR EZ28, so I bought a Toshiba, which stabilizes the picture but does not offer a Flex Recording option. Since 99% of what I dub are Sporting Events, varying time lengths are the rule rather than the exception. I rarely ever dub without needing to utilize the Flex Record feature.
Is Flex Record a feature exclusive to Panasonic???
Both Pioneer and Toshiba built Toshibas('06 and earlier I believe) had a similar flexible recording setting. Both use a MN setting which I believe has settings for 1/10th of a hour increments. AFAIK Panasonic is the only one left with such settings. I use basically FR and occasionally SP and LP. If you had a Panasonic w/HDD(like my new EH-59) you'd find out how much easier it is to use FR with multiple titled DVDs. The EH-59 runs ~$279 for a like new floor model, mine came with the original box.
http://www.bhphotovideo.com/c/product/800736506-USE/Panasonic_DMR_EH59GA_K_DMR_EH59GA_...B_HDD_DVD.html
Note the international Panasonics don't have a North American tuner but record from line outputs(cable box, DVR, etc.) just fine and work on either 220v or 120v.
How can I delete a "frozen" HDD recording on a Philips DVDR3575H/37
By pfflamingo in forum DVD & Blu-ray RecordersReplies: 19Last Post: 29th Sep 2011, 15:47 -
HD camera for recording small LCD screens + "normal" use?
By sincostan45 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 15th Mar 2010, 01:08 -
Should brick and motor websites offer "in store" only search categories?
By yoda313 in forum Off topicReplies: 6Last Post: 23rd Feb 2010, 22:59 -
"On the fly recording" and two burners on same SATA channel
By Disco Makberto in forum Newbie / General discussionsReplies: 5Last Post: 30th Aug 2009, 03:36 -
Will digital broadcasts have "IDs" to aid in DVR recording?
By ebenton in forum DVB / IPTVReplies: 10Last Post: 26th Apr 2008, 05:55
