  1. Member wulf109's Avatar
    Jul 2002
    I've got some DVD's that were 4:3 TV episodes that were recorded as 16:9 with distorted AR. How can I change these back to the correct 4:3 AR?
    Apr 2004
    Miskatonic U
    If the problem is simply incorrect AR flags then you can correct these with a mixture of IFOEdit to fix the IFO files, and DVD Patcher to fix the VOBs.
    If the problem is that the video is strched and fixing then AR flags cannot get it back then you will have to resize the image and re-encode
    Read my blog here.
