Hi:
I have four sabrent USB-AVCPT capture cards plugged in to one PC via a gigaware powered USB hub, each tied to a different camera. This gives all of the capture cards the same designation. This isn't a problem for AMCap.exe, since it can recognize all four cameras; however, the software I am working on can not. The software in question uses the Microsoft DirectShow API to view the cameras. The way it is it can only recognize one of the cameras (or two, if you tie one to port two of the Gigaware hub). I was wondering if there was a way to modify the Directshow API to recognize all of the cameras when implemented in the program I'm working on? Thank you in advance.
Results 1 to 1 of 1
Locked MKV files, Multiple Instances of Explorer, PC Lag
By pushkin69 in forum Software PlayingReplies: 3Last Post: 9th Nov 2011, 23:22 -
Multiple instances of an actor in same shot, with moving camera
By wildpozzer in forum Capturing and VCRReplies: 4Last Post: 12th Mar 2010, 03:36 -
Multiple instances of tmpgenc?
By Bully9 in forum Video ConversionReplies: 1Last Post: 25th Aug 2008, 22:14 -
Help with drivers? Initialization in my Capture Card!1
By hkseo100 in forum Capturing and VCRReplies: 0Last Post: 7th May 2008, 20:41 -
multiple instances of dshow being activated
By radman202 in forum Newbie / General discussionsReplies: 1Last Post: 29th Jan 2008, 10:50
