    Mar 2004
    Wheeling, WV
    So Im trying to split up videos of 1.5 hr + length to put into Youtube, but I cant find a program that will do it for me.
    I've tried Adobe Premier, but it crashes as soon as I insert the movie file. The files are .flv files and I'm wondering if getting it into a different file extension such as .avi or .mpeg would make my editing software not crash...
    Youtube requires segments to be less than 15 minutes each.
    Any ideas?
  2. if it's avc/h.264 in an flv and some sort of mpeg audio avidemux can open it and export it in avi while using the copy mode on audio/video.
    Set the container option to avi and click configure then set splitting to 10mb or whatever youtube excepts, I'd save in a folder because if your video is 500mb you'l have 50 avi's also this will be the result:
    testvideo.avi testvideo.avi01 testvideo.avi02 testvideo.avi03 etc...... you have to remove the 01,02,03 and rename to testvideo1.avi testvideo2.avi....
