There's probably a simple explanation. Media info shows the following info for an avi file: file size 701mb video stream size 502 mb audio 51.9mb. I alsways assumed that the audio and video sizes pretty much aggregated to the file size.
And if i run the file through virtualdub in direct stream copy mode, the file size decreases to 560MB
So what is the 140-odd MB in the original file"doing"?
It's no biggie i don't think, but i'd be interested to know what's happening.
MediaInfo doesn't show any other streams in the original file?
AVI files can have padding to align frames on power of 2 boundaries. But 150 MB of padding in a 701 MB file is excessive. You can use VirtualDub's hex editor with its RIFF chunk viewer to see what extra chunks there are. -
No other streams, but it transpires that the video SHOULD be 10 minutes longer, ie it cuts off 10 mins from the end.
Media Info Not seeing all subtitles
By cal_tony in forum SubtitleReplies: 0Last Post: 15th Apr 2012, 22:43 -
CD media query...
By mjl1297 in forum MediaReplies: 4Last Post: 17th Nov 2010, 23:35 -
Media Info and AVISynth
By ZedVamp in forum Video ConversionReplies: 0Last Post: 7th Feb 2009, 14:25 -
Need advice on divx/xvid media player file query??????
By Humbug in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2008, 18:39 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 22:35
