Hi. I have a Kaiser Baas K100, basically here's all the details about it:
Enjoy HD movies, music and photos on your TV from a USB device or network
Wireless dongle included.
The Wireless MediaPlayer connects to your TV and allows you to play your movies, music and photos from a USB memory stick, USB Hard Drive, USB DVD-ROM, or from a PC or Storage device on your network. The WiFi MediaPlayer is supplied with a USB WiFi dongle so there is no need to have a wired network port near your TV.
Main features:
- Stream media over wired or wireless network
- Play files from USB Storage devices
- 1080P High Definition
Other features:
- Wired or WiFi network streaming - Stream media across your wired or wireless network from your PC or NAS (Network Attached Storage) to your TV
- Play media from USB storage devices - Play movies, music and photos from USB storage devices, including USB memory sticks and external hard drives
- Full HD video playback - Watch Full 1080P High Definition formats, including MKV, H.264, M2TS, BDMV, BDISO and listen to superior digital audio
- NAS, BitTorrent function, file copy and play DVDs - Turn your external hard drive into a NAS, download BitTorrents, copy files bewteen USB devices and play from USB drives
Specifications:
- Wifi out of the box! Supplied with 11n USB dongle.
- Copy files between USB devices, great for file sharing.
- Supports all major video formats, DVD playback with menu navigation and Blu-ray playback
- Supports all major audio formats, Dolby Digital and DTS
- Supports all common file formats,able to play slideshow with music and supports panning and zooming
- Network LAN connection, WiFi connection and able to stream from a PC or from a DLNA compatible media server
- USB ports available, supports connection of a USB DVD-Rom, able to access multiple hard drives simultaneously and supports connection of cameras and MP3 players
- HDMI,Component,Composite and Optical connections
- NAS & BitTorrent, able to access USB hard drive over the network, supports BitTorrent downloads, able to download BitTorrent files while playing a media file
- Volume control on the remote
- Video decoding
- Video codec: MPEG1 / 2 / 4, Divx, Xvid, H.264, WMA, VC-1, RM / R MVB
- Format: WMV, MKV, MOV, AVI, MP4, MPG, TS / M2TS / TP, ISO, IFO, VOB, DAT, RM / RMVB, BDMV, BDISO, MTS
- Audio decoding: MP3, WMA, AAC, WAV, OGG, Dolby Digital, DTS
- JPEG decoding: JPEG, PNG, BMP, GIF
- Network connection: RJ45 10 / 100M connect and via WiFi dongle (included)
- Subtitle: SMI, SRT, SUB, SSA
- Video output: Composite / Component / HDMI
- Audio output: Stereo / Digital HDMI / Optical
- USB: Host 2.0 x 2
- Dimensions: 160 x 120 x 45 mm (width x height x depth)
- Power adapter: AC input: 100 - 240V, 50Hz / 60Hz, DC output: 12V, 1.5A
Now, my problem is, for some reason it plays some AVIs and MKVs and others it doesn't.
I've included a comparison of 2 MKVs using media info. I can't tell the difference but I'm hoping somebody can, and can tell me why it's playing one and not the other.
File 1:
General
Unique ID : 236668872245401296233806493843487371970 (0xB20CC44CC1194B66BFECC572AA9EB2C2) Complete name : C:\inception\I.N.C.E.P.T.I.O.N.2010.D.BDRip.720p.m kv Format : Matroska File size : 7.66 GiB Duration : 2h 28mn Overall bit rate : 7 407 Kbps Encoded date : UTC 2010-12-03 18:28:38 Writing application : mkvmerge v2.3.0 ('Freak U') built on Sep 8 2008 18:32:16 Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 9 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2h 28mn Bit rate : 5 254 Kbps Width : 1 280 pixels Height : 534 pixels Display aspect ratio : 2.35:1 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.321 Stream size : 5.29 GiB (69%) Writing library : x264 core 108 r1766+332 1be361f Encoding settings : cabac=1 / ref=10 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=tesa / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=0.70:0.05 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / fgo=0 / bframes=6 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=5254 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=40 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.70 Language : English
Audio #1
ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : A_AC3 Duration : 2h 28mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 678 MiB (9%) Title : DD@640kbs@5.1, Дубляж Language : Russian
Audio #2
ID : 3 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 2h 28mn Bit rate mode : Constant Bit rate : 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Stream size : 1.56 GiB (20%) Title : DTS@1536kbs@5.1, Оригинал Language : English
Text #1
ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : Force@BD Language : Russian
Text #2
ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : Full@BD Language : Russian
Text #3
ID : 6 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : Force@BD Language : English
Text #4
ID : 7 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : Full@SDH Language : English
Menu
00:00:00.000 : en:Scene 1 00:11:41.743 : en:Scene 2 00:21:37.338 : en:Scene 3 00:31:20.337 : en:Scene 4 00:41:22.230 : en:Scene 5 00:51:13.737 : en:Scene 6 01:01:21.553 : en:Scene 7 01:10:29.684 : en:Scene 8 01:22:15.597 : en:Scene 9 01:31:52.590 : en:Scene 10 01:40:38.532 : en:Scene 11 01:51:22.175 : en:Scene 12 02:00:54.414 : en:Scene 13 02:10:09.051 : en:Scene 14 02:20:55.447 : en:Scene 15This one works.
File 2:
General
Unique ID : 203362081507007491947795268632952810975 (0x98FE1CBB48B132D5891439C302F5ADDF) Complete name : C:\onion\aaf-onn.s01e03.720p.mkv Format : Matroska File size : 559 MiB Duration : 21mn 38s Overall bit rate : 3 611 Kbps Encoded date : UTC 2011-02-05 04:03:35 Writing application : mkvmerge v3.4.0 ('Rapunzel') built on May 15 2010 09:38:20 Writing library : libebml v0.8.0 + libmatroska v0.9.0
Video
ID : 2 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 21mn 38s Bit rate : 3 224 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.117 Stream size : 488 MiB (87%) Writing library : x264 core 112 r1867 22bfd31 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=20 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3224 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 Language : English
Audio
ID : 1 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : A_AC3 Duration : 21mn 38s Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 59.4 MiB (11%)
This one doesn't. Could somebody please help?
Closed Thread
Stop downloading the movies and rip them yourself, then you can create the correct files for your player.
http://www.google.com/#hl=en&sugexp=ldymls&xhr=t&q=I.N.C.E.P.T.I.O.N.2010.D.BDRip.720p...18c74a530&bs=1
http://www.google.com/#hl=en&sugexp=ldymls&xhr=t&q=aaf-onn.s01e03.720p&cp=19&pf=p&scli...26f1018c74a530
Most standalone players can be picky about certain formats. One file had a much higher bitrate was all I noticed, but that could be the problem or it might be something else. Could just be a corrupted file.
I would recommend either check a dedicated forum for that particular device or test a large number of files whose parameters you are familiar with.
Why won't my TV play certain MKV files?
By MrFriendly in forum DVB / IPTVReplies: 27Last Post: 24th May 2016, 15:00 -
WIFI AC and WIFI AD coming in the next few years
By yoda313 in forum ComputerReplies: 0Last Post: 31st May 2011, 10:01 -
YouTube and the Archos 605 WiFi: Why won't the source MP4s work?
By Bix in forum Portable VideoReplies: 6Last Post: 12th Sep 2010, 15:29 -
mpg files won't play in IE
By Krispy Kritter in forum Software PlayingReplies: 3Last Post: 31st Oct 2008, 14:42 -
Some video files and movie files won't play
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 21st Feb 2008, 11:08
