Hi Everyone,
I use eac3to to rip the audio tracks of Blu Ray disks for later use in the creation of MKV files.
Usually I rip the DTS Core Master Audio track. To do this I must use the -core switch with eac3to. However recently it has come to my attention that the "Core" track is potentially a lossy track, and in an effort to rip lossless audio I have reverted to not using the -core switch.
When I rip without the -core switch I get the following error message in my eac3to log:
When I create my MKV files using MKVMergeGUI merging takes a very long time with files that present the above error (about 10 times longer than when I merge audio tracks that I used the -core switch with). Other than the long time that MKVMergeGUI takes to create the final MKV there don't appear to be issues with the audio / video synch.Warning: dts_packetizer: skipping 720 bytes (no valid DTS header found). This might make audio/video go out of sync, but this stream is damaged.
Can anybody explain why this may be happening?
Tricky question!
Davo
Results 1 to 1 of 1
eac3to: error converting 6.1 ch DTS -> AC3
By KushSmoka420 in forum AudioReplies: 5Last Post: 6th Mar 2012, 11:35 -
EAC3TO error
By soadtrails in forum Video ConversionReplies: 0Last Post: 28th Feb 2010, 19:31 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
