Hey folks
I've got a serious problem. I've read all the help files and tutorials on how to make Divx movies to VCD and adding subtitles but I still cant overcome a major problem. I'm not able to track it down and I do everything as I've read. The mpeg1 file encoded by TMPGEnc 2.53 (with VFP plugin installed) is w/o subtitles. I'm running Virtual Dub 1.3d (I'm now downloading 1.4d and 1.4.9 if that makes any difference at all), with the subtitles filter plugged into Virtual Dub, and installed handler. When
I'm previewing the movie in Virtual Dub using the subtitles filter everything is perfectly fine. I'm starting the server to pass parametars to TMPGEnc, but after opening the .vdr file into TMPGEnc and hitting the start(encode) button I dont see any text!!!! The mpeg file is encoded w/o subtitles!! Why?? I get mpeg layer 1 movie as if I wasnt using virtual dub at all and it doesnt generate the permanent subtitleinto the movie?!
And I'm downloading now Vobsub 2.09 if that makes difference,will try it.
And downloaded the latest Virtual Dub just now.
computer configuration:
Pentium4 1,4GHz;
256RDRAM;
Geforce2 MX 400 64MB;
huge harddisk
some creative 5.1 soundcard..
Thanks in advance!!
p.s. I searched today the forum for subtitles in the last three months(i'm new to the Divx stuff and subtitling) and I realized that people had/have problem loading the .vdr file. Once you save it in Virtual Dub (at least in 1.3d) you have to add the extension .vdr explicitly,otherwise the file would be w/o extension and thats why TMPGEnc is complaining.
p.p.s. Huge thanks to Arminio Grgic for his program SUB to SSA and his implementation of the character set required for southeastern europe folks! Great work dood!
It works Now! after downloading Virtual Dub 1.4.9. It didnt work well with
1.3d
Need Help about Professional Subtitling
By kei_siuip in forum SubtitleReplies: 1Last Post: 14th Mar 2011, 03:04 -
can't open mpg 2 and flv video files with tmpgeng xpress 4.0
By monks19 in forum Video ConversionReplies: 0Last Post: 8th Oct 2010, 00:53 -
Subtitling on the Mac
By sky captain in forum MacReplies: 2Last Post: 12th Jan 2010, 13:16 -
mkv subtitling
By eliqush in forum EditingReplies: 6Last Post: 19th Jun 2009, 03:11 -
Subtitling. Thanks in advance.
By shr3dd3r in forum SubtitleReplies: 4Last Post: 11th Sep 2007, 14:21
