I used this guide to setup my media playback http://files.nyaatorrents.org/HOW_DID_I_PLAYED_BACK.txt, except instead of CoreAVC i used ffdshow tryouts and now when i play a file that has multiple audio or subtitle tracks in it the haali media splitter tray icon wont show up anymore, was working fine until i updated mpc home cinema and ffdshow
Anyone able to help me get it working again?
On my XP HTPC, it's set to show in the tray, but doesn't unless it's actually in use, like when running BDRB.
At any rate it should be in your start menu under Programs -> Haali Media Splitter -> Media Splitter Settings -> Options -> Interface -> Show Tray Icon. Yes -> Apply -> Close.
Alternatively go to Start -> Run -> regedit -> HKEY_CURRENT_USER -> Software -> Haali -> Matroska Splitter. Click on "ui.trayicon". Set the hexadecimal value to 1 for yes, 0 for no. Okay -> Close.
I presume it's the same for Win7.Pull! Bang! Darn! -
Its set to yes in Haali Media Splitter settings and it has a value of 1 in regedit but it still doesnt come up when i open a video file with MPC
Iv tried uninstalling everything and then reinstalling but it doesnt seem to fix it
Haali Media Splitter, LAV Filters, AV Splitter...How do these filters work?
By Moontrash in forum Software PlayingReplies: 3Last Post: 25th Feb 2012, 19:00 -
FFMpegSource2 does not use Haali Media Splitter
By wateshadon in forum EditingReplies: 9Last Post: 10th Sep 2010, 07:03 -
Gabest MP4 splitter vs. Haali Media Splitter
By jaduvil in forum Software PlayingReplies: 4Last Post: 16th Jun 2010, 12:57 -
Suddently Haali Media Splitter is no longer in use?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 22nd Nov 2008, 19:20 -
Haali media Splitter Errors
By SWBisbee in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2007, 16:45
