Since YouTube only play videos at 30fps and not 60fps, are there any reasons to shoot my videos at 60fps?
If you're planning on doing any slow motion or have another end target in mind
Heck yeah, why shoot video to the level of the lowest common denominator?
When 60 frames is reduced to 30, it's like de-interlacing with the blend frame being actual footage, not interpolated. -
I'm new to 60fps. I just though that since YouTube plays at 30fps, there would be no reason for shooting at 60fps because I assumd the 60fps video would just look like 30fps after YouTube turns it into 30fps
Can you explain what this means? I know what de-interlacing is but what do you mean by interpolated? -
The blend will be ALL from source material, and each original source frame will be twice as sharp as 30 frames. So the resulting YT file will be better quality.
"Interpolation" is a de-interlace scheme whereby the blend is a best guess estimate. -
So to get better quality, I will shoot 60fps rather than 30fps.
My final video will be 30fps since YouTube's maximum frame rate is 30fps. I need to render the video to make it 30fps.
How do I work with my 60fps video in Sony Vegas Movie Studio HD Platinum 10?
I guess when I render, I'd set the custom settings to 30fps. But what about my project settings? Should it be set to 60fps or 30fps?
How do I convert 60fps to 30fps to halve file size?
By DigitalOxygen.ca in forum MacReplies: 33Last Post: 11th Jul 2012, 22:27 -
Encoding 30fps from 60fps source, keep maximum smoothness?
By squall0833 in forum Video ConversionReplies: 22Last Post: 13th Apr 2012, 00:57 -
New Canon slr to shoot 1080p @30fps
By aedipuss in forum Latest Video NewsReplies: 29Last Post: 25th Oct 2010, 11:40 -
Converting a 60fps .MTS video to a 30fps raw .AVI?
By Anon1 in forum Newbie / General discussionsReplies: 1Last Post: 20th Jun 2010, 16:57 -
Converting 720p/60fps file to 30fps?
By mt123 in forum Newbie / General discussionsReplies: 11Last Post: 17th Nov 2009, 13:34
