Hope i chose the right forum to post this question.
As the title says, I'm having some trouble with the program ULEAD DVD MovieFactory 5 SE occasionally (although it seems the problem is not in the software).
Some of the clips i want to record end up without any audio on DVD. All the clips I use are the same, so I don't understand what causes this problem that most clips are alright, but some kept being recorded to DVD without sound. The original clip DOES have sound. The files I record are .mpg files I get from my TV card COMPRO Vista E800F.
Tried recording the problematic clips again but again same result. Even tried using several other programs with the same result, I managed to record one of the clips using a random trial program I found on the internet but it kept adding watermarks to the clip which was annoying, so i deleted it afterwards (not sure anymore what the title of the software was).
It's getting realy annoying.
Does anyone got any idea what I should try to do to solve this?
Thx.
Ulead DVD MovieFactory 6 not making maximum use of DVD space
By GSP_87 in forum Authoring (DVD)Replies: 6Last Post: 6th Nov 2009, 04:54 -
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 04:05 -
dvd moviefactory 5
By bigz704 in forum Newbie / General discussionsReplies: 0Last Post: 24th Sep 2009, 14:54 -
Recording new audio track for DVD
By mindfield in forum AudioReplies: 0Last Post: 18th Jan 2008, 13:30 -
Ulead DVD MovieFactory 6 - Doesn't recognize DVD
By urlilgurl017 in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2007, 12:52
