Hello
I need to know how to use the new Mplayer rc4 (SVN-r32848-4.2.5 win32) to play BLuRay Discs.
The BluRay i tryed to play is NOT copy protected! (of course not)
When i try to start Mplayer with this command:"mplayer br:// -bluray-device d:\bluray-data" i get an error massage that says:
>Playing br://.
>No stream found to handle url br://
According to the manual this command should work, but i guess there is another trick neccessary to get Mplayer to play the BD...
My Video files are in d:\bluray-data\BDMV\STREAM\... and playable.
I tried other switches and paths, but nothing worked so far.
Can anyone help me, please?
bye
Isn't it just br:////pathtoyourblurayfolder ? I don't think it support blu-ray menus,etc yet.
mplayer br:////d:\bluray-data\BDMV\STREAM
doesnt give any results too
i think you are right, thats because it should start play the longes movie on Disc when started manually (i read it somwhere on the i-net)I don't think it support blu-ray menus,etc yet.
Can you fit multiple movies on bluray media?
By rz514 in forum Authoring (Blu-ray)Replies: 12Last Post: 28th Apr 2013, 00:29 -
Help with MPC-HC to view Bluray
By calabuig1969 in forum Software PlayingReplies: 0Last Post: 20th Jan 2010, 10:45 -
Add movies to my DVR so that I can view them on my TV?
By dmickey in forum DVB / IPTVReplies: 5Last Post: 29th Dec 2009, 17:03 -
single files for bluray movies..
By krohm in forum Blu-ray RippingReplies: 2Last Post: 6th Dec 2009, 12:19 -
Can't play or view atleast any of my movies
By metsven in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2008, 08:35
