Hi there,
I've been trying to convert some MKV files with dual audio (Language) tracks to avi and am coming across a problem. When I do, selecting one track obviously the volume level is always much lower. So far I've tried AlltoAvi and Prism video and they both present the same issue. Can anyone point me to a converter that won't do this or what settings I should be using with my current converters?
Many Thanks
These are the audio details of a MKV file I converted.
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 23mn 26s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 75.1 MiB (22%)
Language : English
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 23mn 26s
Bit rate : 256 Kbps
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 42.9 MiB (13%)
Language : Japanese
These are the audio details of the AVI file I converted it to.
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Codec ID/Hint : Microsoft
Duration : 23mn 26s
Bit rate : 1 536 Kbps
Bit depth : 16 bits
Stream size : 257 MiB (63%)
Interleave, duration : 166 ms (4.99 video frames)
Interleave, preload duration : 469 ms -
How about keeping it as ac3? You can do it in for example xmedia recode and avidemux. Choose copy under audio.
VirtualDubMod can mux multiple AC3 audio streams into an AVI. It can't read MKV files though. You'll have to demux them with MkvExtracGui.
MKV to AVI without quality loss - for watching on DVD player
By mr-scarface in forum Video ConversionReplies: 19Last Post: 17th Apr 2013, 16:59 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
By Markomaani in forum Video ConversionReplies: 10Last Post: 15th May 2009, 09:51 -
converting OGM/MKV to AVI (with dual audio track)
By mwasim1 in forum Video ConversionReplies: 1Last Post: 4th Jan 2009, 22:54
