    Feb 2010
    Sacramento, CA
    I'm using Any Video Converter] (free version) to convert an mpg video to AVi (vxid codec). See Media Info for the source file below. It is obviously a 6 channel AC-3 file/ using the AVI profile in Any Video Converter shows that it wants to convert to 2 channel. All I really want is for it to convert the file to AVI using all of the same audio/video settings. My reason for the conversion is that via TVersity, my Samsung C5500 doesn't support rwnd/ffwd/pause/etc for mpg files. Works GREAT for AVI. Same for the XBox 360, which will only play mpg files if transposed in real time by TVersity, a cpu intensive process my media server can't support...
    I included media (Working file) info for an mpg file that I converted using a trial version of another tool... But unfortunately I can't afford to buy it...
    If I'm barking up the wrong tree or a more complex solution than I need, please let me know. My research and test file shows AVI (divx) as the best format for my needs....
    What am I missing in the Any Video Converter settings? Is Any Video Converter the best tool to do this? I do need batch processing as I have a number of mpg files to convert... Any advice would be greatly appreciated.
    Other Specs:
    I am running Win 7 Home Premium on an I7-820QM, 8gb RAM laptop for my conversions as I need the processing power... My media server runs Windows XP Media Center, Pentium 4 2.8ghz, 4gb RAM
    ANY VIDEO CONVERTER "Customized AVI Movie" SETTINGS:
    Video Options
    Codec: XVid Frame Size: 720x480 video bitrate: 768 framerate: 25
    Audio Options:
    Audio Codec: Original Bitrate: 128 sample rate: 44100 Audio Channel: 2 Disable Audio: No A/V sync: basic Audio Track: Default Subtitle: none
    SOURCE FILE: MEDIA INFO OUTPUT
    General
    Complete name
    Format : MPEG-PS
    File size : 6.65 GiB
    Duration : 1h 26mn
    Overall bit rate : 11.0 Mbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Duration : 335ms
    Bit rate mode : Variable
    Bit rate : 10.3 Mbps
    Nominal bit rate : 9 800 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Scan order : 2:3 Pulldown
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 1.248
    Stream size : 423 KiB (0%)
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Duration : 1h 26mn
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 277 MiB (4%)
    Text
    ID : 224 (0xE0)-DVD-2
    Format : EIA-608
    Muxing mode : DVD-Video
    Muxing mode, more info : Muxed in Video #1
    Stream size : 0.00 Byte (0%)
    WORKING FILE: MEDIA INFO OUTPUT: PREVIOUSLY CONVERTED VIDEO - works great on C5500 and XBox 360 --> used trial version of other software product... cannot afford
    General
    Complete name : I:\AVI\AVIfile.avi
    Format : AVI
    Format profile : OpenDML
    File size : 1.51 GiB
    Duration : 1h 32mn
    Overall bit rate : 2 335 Kbps
    Movie name : AVIFile
    Writing application : Lavf52.78.4
    Original source form/Name : AVIFILE_16X9
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L5
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Muxing mode : Packed bitstream
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 1h 32mn
    Bit rate : 1 875 Kbps
    Width : 720 pixels
    Height : 386 pixels
    Display aspect ratio : 1.865
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.281
    Stream size : 1.21 GiB (80%)
    Writing library : XviD 1.2.1 (UTC 2008-12-04)
    Audio
    Format : AC-3
    Codec ID : 2000
    Duration : 1h 32mn
    Bit rate : 448 Kbps
    Bit depth : 16 bits
    Stream size : 296 MiB (19%)
    Alignment : Aligned on interleaves
    Interleave, duration : 32 ms (0.77 video frame)
    Interleave, preload duration : 32 ms
    Menu
    You can keep the ac3 with better converters. Try for example autogk, staxrip, avidemux, xmedia recode. Under audio choose copy.
