I get this message sometimes after recording something with VM Recorder:
This drives me crazy, how do I disable this? I couldn't care any less about the codec.could not render some of the pins in the graph, you may not have the needed codecs of filters installed on the system.
If you have ffdshow, you could probably just activate the needed decoders quite easily.
If you don't care about MPC, why are you playing it?
Perhaps it's being started automatically by your recording app.
If so, there is probably an option to not to do that, or to use something else (like VLC, say, that has most codecs built in). -
How do I do that?
I followed some online guide earlier for FLV (enabling the decoders) but I am still getting the same error.
what does this mean 'pins in the graph' RE: FLV file.
By talx in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2011, 11:26 -
Output of both m2v AND ac3 during single "Render As" event in Vegas?
By Smells_Like_Feet in forum EditingReplies: 3Last Post: 28th Oct 2011, 19:08 -
MPC "cannot render the file" on some .M2TS files, but not all??
By insaneoctane in forum Blu-ray RippingReplies: 2Last Post: 24th Jun 2010, 10:45 -
What are "Source" and "Transform" filters in MPC?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2008, 21:20 -
Disable "Activation Keys" in FFDSHOW
By Xenogear900 in forum Software PlayingReplies: 0Last Post: 14th Dec 2007, 22:54
