  1. Member Mr anderson's Avatar
    Jan 2004
    hi,
    I am having problems with my usb dongle/modem, make zte mf112 hsupa usb stick(zte wcdma technologies msm) (XP). the first half of the installation works fine but then it asks for drivers which i do not have, i have had a look thru the web and at the point of pulling wht little hair i have left out.
    PS: i have scanned the dongle for the extra drivers and no luck either.
    many thanks
    Oct 2005
    666th portal
    Installing your software onto your Windows PC Once your USB modem is connected, you may have to wait a few minutes before the software installation wizard starts.
    • Read and accept the User License Agreement if it pops up.
    • Follow the installation wizard and the software will be installed automatically.
    (Don’t follow the Windows Driver installation wizard if offered because this won’t fully install the software).
    The software takes a few seconds or a few minutes to install, depending on your computer.
  3. Member Mr anderson's Avatar
    Jan 2004
    hey, thanks for the reply, finally got it working.
