Hi all,
I have a WD Media Player and I am trying to figure out how to attach pictures to avi files so that when you browse the movies it shows thumbnail pictures. At the moment I just get a blank folder icon with the movie name underneath. I'd really like to change the folders to the movie artwork.
Any ideas how to do this?
jpg thumbnail with the same name as the movie. It's covered in the manual. Two ways to do, one is a thumb for the entire folder and the other is a same name jpg as the movie. Personally I gave up on thumbnails as it seemed to slow things down.
If I'd known I was going to live this long, I'd have taken better care of myself. -
Dont you need a modded fimware for the WDTv something like B-rad's firmware and use thumbgen on your PC..
Try http://wdtvforum.com/main/ for all your needs.Corned beef is now made to a higher standard than at any time in history.
The WDTV has always had issues with thumbnails. The basic procedure is as TBoneit described. But after changing a thumbnail you may need to delete the thumbnail cache so the unit rebuilds thumbnails. And it doesn't work right with network shares. I forget the details, I use plain text list mode.
Showing .ts subtitles using a Western Digital media player
By pooksahib in forum SubtitleReplies: 4Last Post: 31st Jul 2011, 03:38 -
Western Digital TV Live HD Media Player
By dvdsham in forum Newbie / General discussionsReplies: 4Last Post: 1st May 2010, 23:32 -
Thumbnail problem with Western Digital HDMi Media Player
By paulpeople2476 in forum Media Center PC / MediaCentersReplies: 2Last Post: 26th May 2009, 23:51 -
Western Digital HD MEdia Player alternatives?
By peggypwr1 in forum Newbie / General discussionsReplies: 13Last Post: 28th Feb 2009, 16:15 -
Universal remote-Western Digital WD TV HD Media Player
By interpidp in forum DVB / IPTVReplies: 4Last Post: 8th Jan 2009, 02:57
